pbarham
Feb 22, 2021Apprentice
RBR50 Can't check for firmware updates
My RBR50 no longer seems to be able to check for firmware updates and says "Service Unreachable": Any ideas on how to fix this?
vajim
Feb 22, 2021Master
just a comment..when the OP used the words 'no longer' that sounds like it was working and now is not. In the case of a double NAT, that would have reared its ugly head from day one.
pbarham
vajim wrote:just a comment..when the OP used the words 'no longer' that sounds like it was working and now is not. In the case of a double NAT, that would have reared its ugly head from day one.
That is correct. The Orbi had been working fine - and the firmware update checks used to work OK.
After various other problems I had with the router, I ended up needing to install specific firmware versions manually. At some point (i dind't notice when) the update check stopped working.
This problem has persisted across many power cycles/ reboots, and across more than one manual firmware update.
I am happy to install firmware manually - but don't check very often - and it concerns me that I may miss important security updates.
- vajimFeb 22, 2021Master
Security updates of any consequences are supposed to be pushed automatically. No user action required. If your system is working I'd let go.
- pbarhamFeb 22, 2021Apprentice
vajim wrote:
Security updates of any consequences are supposed to be pushed automatically. No user action required. If your system is working I'd let go.That is precisely the functionality that I think isn't working. My router did not update to .104 automatically, and does not know that it exists.
My system *is* currently working OK from a functionality standpoint, and I would not normally update it unless there was a relevant looking bugfix.
I think the auto functionality is a perception of the user
you and others think since it missed a certain update it's broken, the reality may be that missed update wasn't as critical as some claim as least not within the first few months. Dozens of immediate firmware downloaders fall victim with each release
But it's your orbi you decide if it works or not
- FURRYe38Feb 22, 2021Guru - Experienced User
You can manually download and manually apply FW updates if you want too:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
pbarham wrote:That is correct. The Orbi had been working fine - and the firmware update checks used to work OK.
FURRYe38 wrote:You can manually download and manually apply FW updates if you want too:
Poster knows how to perform manual updates.
