surrebral
Aug 29, 2023Aspirant
RBR50 can't connect to router
Hi all. Long-shot here. Recently, the Orbi lost WiFi after my ISP made changes that caused issues. Although they've resolved the issues, I haven't been able to get the Orbi to work as a router. ...
Aug 29, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
If you press the reset button of 15 seconds on the RBR with the RBR disconnected from the ISP modem and just one wired PC connected to any of the white LAN ports in back, not the yellow port, give it one minute, can you access the RBRs web page at 192.168.1.1 at all in a web browser? You should see a setup page and Orbi app picture on the page.
Be sure to set the PC for automatic IP addressing configuration.
surrebral
Thank you for the response!
The ISP is from OzarkGo and fiber. Seems to be a "black box" where I’m not seeing any info on the manufacturer or the model. I only get the default settings. There is an ethernet port, and I had to work with them to confirm that they’re receiving signals to the Orbi. They can only recognize the Orbi when the router is in passthrough mode.
I was using a CAT5, and I have a CAT8. I’ll see what else I have.
Oh, and that seems to be the issue as well. When connected to a white LAN port, I get a self-assigned IP.
Also, should there be any changes to the power led while pressing the reset button? Seems to be stuck in power led green and router ring led blinking white. I can only get a change when first booting and pressing the reset button for 15 seconds. And that’s when I’m getting the self-assigned IP.
I've been trying to get into the web browser for the settings and struggling to get into it.
- FURRYe38Aug 29, 2023Guru - Experienced User
Ok, try a 30-30-30 reset on the RBR with it still disconnected from the ISP ONT.
https://www.lifewire.com/hard-reset-rule-for-routers-3971318
After last one, then release, give it a minute then see if your PC gets an IP address from the RBR and if you can access 192.168.1.1
- surrebralAug 29, 2023AspirantDarn, same issue: self-assigned IP and no internet.
I'm wondering if there's something defective with the router. It only seems to work like an access point. It doesn't seem to function as a router anymore.- FURRYe38Aug 29, 2023Guru - Experienced User
Can try re-installing the FW using the TFTP method:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflashIf this fails, then the RBR maybe toast and needs replacing.
