Darrellsnook
Jan 19, 2022Aspirant
RBR50 Can't fully remove Circle Parental Controls
I followed the instructions to disable Circle parental controls since I wanted to use the new built-in parental controls. Everything seemed to go smoothly, but my children's phone still seem to be ge...
Darrellsnook
Jan 20, 2022Aspirant
Thanks for the advice. I'll give it a go this weekend and report back here.
Chuckg1
Feb 11, 2022Star
Netgear SPC does not work and require factory resets every time it fails. You should stay away from it at any cost.
