csturmer
Dec 07, 2021Aspirant
RBR50 Capped LAN ports at 100mbps
For several months I have been trying to off and on to isolate a consistent capping of my LAN ports on the RBR50. I pay for 300mbps from Spectrum and consistently get 220-250 mbps over WIFI (dependi...
Dec 07, 2021Guru - Experienced User
What is the brand and model # of the ethernet adapter using in the wired PC?
What is the brand and model of the LAN switch being connected?
Ensure your ethernet adapter drivers are up to date and the adapter supports 1000Mpbs connection rates.
What CAT# cables are you using? CAT6 is commended.
Be sure your using good quality LAN cables. Swap LAN cables to test. Check your LAN cables.
The RBR supports 1000Mpbs on the LAN ports. The LAN ports auto detect the speed. Bad cables, bad jacks or unsupported ethernet adapter cards can effect the connect rate.
