mxcramer
May 10, 2020Guide
RBR50 Causing Intermittent Internet
My RBR50 is causing my cable modem to drop the line. Over the last two weeks, the intermittency went from about once a day to constant. A reboot of the cable modem and the Orbi would fix it for a mom...
May 11, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
mxcramer wrote:My RBR50 is causing my cable modem to drop the line. Over the last two weeks, the intermittency went from about once a day to constant. A reboot of the cable modem and the Orbi would fix it for a moment, but then I was back offline again.
Spectrum has checked the lines, and a tech tightened some fittings and replaced the cable modem, so I don't think the problem is upstream.
Further, I hard-wired my desktop to the cable modem and the problem stopped. I am not up an running again using my ancient router in place of the Orbi. Again, no drops since this was put in place, so the Orbi is the problem.
Any suggestions on how to diagnose this problem would be appreciated. The old router works but provides much slower speeds throughout the house (the original reason we switched to a mesh system!).
Mike
- mxcramerMay 11, 2020Guide
Firmware 2.5.1.8 installed.
Modem is Hitech E31_2V1.
Line has been checked and has no splitters. All connections on coax reinstalled by cable service last Thursday.
Thanks for any help you can offer.
Mike
- FURRYe38May 11, 2020Guru - Experienced User
Do you have Armor, Circle enabled by chance?
Has a factory reset and setup from scratch been performed since last FW update?- mxcramerMay 11, 2020Guide
Circle is set up, and I think Armor was on but has expired. I have not done a factory reset since the last firmware update, but I will try that next.
Thanks!
Mike
