mxcramer
May 10, 2020Guide
RBR50 Causing Intermittent Internet
My RBR50 is causing my cable modem to drop the line. Over the last two weeks, the intermittency went from about once a day to constant. A reboot of the cable modem and the Orbi would fix it for a mom...
mxcramer
May 11, 2020Guide
Firmware 2.5.1.8 installed.
Modem is Hitech E31_2V1.
Line has been checked and has no splitters. All connections on coax reinstalled by cable service last Thursday.
Thanks for any help you can offer.
Mike
May 11, 2020Guru - Experienced User
Do you have Armor, Circle enabled by chance?
- mxcramerMay 11, 2020Guide
Circle is set up, and I think Armor was on but has expired. I have not done a factory reset since the last firmware update, but I will try that next.
Thanks!
Mike
- FURRYe38May 11, 2020Guru - Experienced User
OK, yes lets reset and setup from scratch. Be sure to not enable Circle or Armor. There was reports of Circle causing problems on v1.8. NG was made aware of this. You might upate to v16 on the system and see if Circle when enabled does anything differently. We haven't got official work if NG fixed Circle or not.
- mxcramerMay 11, 2020GuideFinished refresh of the settings around 5pm, and so far so good. I’ll give it a couple of days before declaring victory. Fingers crossed!
Watching the logs, there are a great number of DoS attacks going on, many from the same MAC address. Is there any profit in spending effort tracking these down?
