r0b0tvampire
May 06, 2021Star
RBR50 Change to AP mode
I have an RBR50 with two matching RBS50 satellites. They are in a mesh configuration (no Ethernet backhaul). The RBR50 is currently connected directly to my cable modem and is the router on my netw...
May 06, 2021Guru - Experienced User
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
r0b0tvampire
May 06, 2021Star
Thanks for the link, but all it really says is how to enable AP mode. I wanted to know if I have to factory reset the router and/or the satelites as well, since it already has a running config.
- FURRYe38May 06, 2021Guru - Experienced User
No you don't.
