r0b0tvampire
May 06, 2021Star
RBR50 Change to AP mode
I have an RBR50 with two matching RBS50 satellites. They are in a mesh configuration (no Ethernet backhaul). The RBR50 is currently connected directly to my cable modem and is the router on my netw...
r0b0tvampire
May 06, 2021Star
Thanks for the link, but all it really says is how to enable AP mode. I wanted to know if I have to factory reset the router and/or the satelites as well, since it already has a running config.
May 06, 2021Guru - Experienced User
No you don't.
