RoBac2020
Apr 16, 2020Aspirant
Rbr50 circle app issues
I decided to have a look at the circle 1st generation app to control use age within the home. The circle has locked the WiFi for everyone, including me. I cannot access anything. It tells me to enter ...
Apr 16, 2020Guru - Experienced User
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thank you.
RoBac2020 wrote:
I decided to have a look at the circle 1st generation app to control use age within the home. The circle has locked the WiFi for everyone, including me. I cannot access anything. It tells me to enter a code, but no code appears when I ask it to send. How do I disable and remove circle from my Orbi?
RoBac2020
Thank you. Will do.
