WSR
Jun 30, 2020Tutor
RBR50 Compatible Extender
I have a RBR50 with the router and one satellite and need to extend the signal to a detached garage. The garage isn't too far away and the Orbi signal actually works out there but it a bit spotty. ...
Jun 30, 2020Guru - Experienced User
Whats the distance from the house to the garage? Anything past 50-60 feet will be to far for Orbi or any extender.
Buried LAN cable would be best...
