WSR
Jun 30, 2020Tutor
RBR50 Compatible Extender
I have a RBR50 with the router and one satellite and need to extend the signal to a detached garage. The garage isn't too far away and the Orbi signal actually works out there but it a bit spotty. ...
CrimpOn
Jun 30, 2020Guru - Experienced User
As FURRYe38 points out, distance is the important factor. If you are willing to give up "the mesh", then there are a host of extenders that might be suitable. You could even start with a Netgear EX3700 at about $40USD (Amazon). It doesn't even have to be from Netgear.
