craig0thomas
Jun 08, 2020Aspirant
RBR50 connected devices report no internet access
I have a RBR50 router with two satellites that is connected to a Cox Cable modem. The system has been working without issue since December 2019 until last week. WiFi devices are working, but I have ...
- Jun 22, 2020
We replaced the TP-Link switch with a Netgear GS308E managed switch. When we set the port speeds to 100M Full Duplex and rebooted all the devices, the Tivo minis were able to access the internet and see the primary Tivo device.
Jun 08, 2020Guru - Experienced User
What happens if you take the switches out of the mix and directly connect 1 or two of the devices to the back of the RBR directly?
craig0thomas
Jun 09, 2020Aspirant
Thanks for your assistance. The cable modem is an Arris TM3402A/CX. My guess is that they performed an updated and it messed everything up. I will try to have two devices cables moved from the switch to the RBR50 router to see if that changes things for them and report back.
- FURRYe38Jun 10, 2020Guru - Experienced User
Let us know what happens.
craig0thomas wrote:Thanks for your assistance. The cable modem is an Arris TM3402A/CX. My guess is that they performed an updated and it messed everything up. I will try to have two devices cables moved from the switch to the RBR50 router to see if that changes things for them and report back.
