GMiner429
Mar 27, 2020Aspirant
RBR50 Connecting 2.4 GHZ and 5 GHZ Devices
I just got an Orbi RBR50 system with a single satellite. I knew going into it I'd have to separate the SSID's which I've done. The issue I'm having is even with the SSID's separated only one is worki...
Mar 27, 2020Guru - Experienced User
Seperating out the SSID's isn't support and can make things work unreliably. Kind of like you're getting.
Is there a reason you want them seperated out?
