GMiner429
Mar 27, 2020Aspirant
RBR50 Connecting 2.4 GHZ and 5 GHZ Devices
I just got an Orbi RBR50 system with a single satellite. I knew going into it I'd have to separate the SSID's which I've done. The issue I'm having is even with the SSID's separated only one is worki...
Mar 27, 2020Guru - Experienced User
Seperating out the SSID's isn't support and can make things work unreliably. Kind of like you're getting.
Is there a reason you want them seperated out?
GMiner429
Yes, I have multiple 2.4 GHZ only devices that will not connect otherwise to the best of my knowledge. Some of the devices are OK, but those that need to connect through my iPhone will not connect, for example several WiFi sockets I have from Leviton.
- tomschmidtMar 27, 2020Virtuoso
Try this method which works for most IoT devices that require your smart phone to also be on the 2.4GHz frequency to configure their WiFi.
1. Launch a web browser from a computer or mobile device that is connected to the Orbi network.
2. Enter orbilogin.com or 192.168.1.1 (IP address of your router's LAN port).
3. The login window opens, enter username "admin" and the password that you configured for your router.
4. Click Advanced tab > Advanced Setup > Wireless Settings.
5. Uncheck the box "Broadcast SSID" for the 5GHz frequency and click Apply to save the settings.
6. Confirm that your smartphone is connected to the 2.4GHz frequency. If it is still connected to the 5GHz frequency, then "Forget" the WiFi network for your SSID, then reconnect to it and enter your SSID password. Now your smartphone should be on the 2.4GHz frequency.
7. Try connecting your IoT device to the Orbi network per its setup instructions.
8. If it works, re-enable the broadcast SSID option for the 5GHz frequency.
9. On your smartphone, turn WiFi off and back on again and it should reconnect to the strongest signal.
10. If your smartphone did not reconnect to the 5GHz frequency, then "Forget" the WiFi network again for your SSID, then reconnect to it and enter your SSID password.I have this posted in the Tips and Tricks on this forum as well.
- GMiner429Mar 27, 2020Aspirant
Before doing this do I need to go back to only a single SSID name. Please remember I am not a tech Saavy guy.
- CrimpOnMar 27, 2020Guru - Experienced User
GMiner429 wrote:Yes, I have multiple 2.4 GHZ only devices that will not connect otherwise to the best of my knowledge. Some of the devices are OK, but those that need to connect through my iPhone will not connect, for example several WiFi sockets I have from Leviton.
It would be really helpful if you can identify these devices. Is this the Leviton plug: https://www.amazon.com/Leviton-DW15P-1BW-Decora-Required-Assistant/dp/B07H3JVZJZ/ref=sr_1_5?dchild=1&keywords=leviton+smart+plug+wifi&qid=1585322488&sr=8-5
Yes that is the Leviton smart plug. Another issue is a Reolink Pro secutiry camera. I've also had instability with Alexa devices.
GMiner429 wrote:Yes that is the Leviton smart plug. Another issue is a Reolink Pro secutiry camera. I've also had instability with Alexa devices.
I will pick up the Leviton switch at Home Depot today. Cameras are almost never a problem because they connect by generating a QR smart code and holding it in front of the camera. I do not have Reolink Pro, but I have two of the original Reolink Argus cameras and they connected without issue.
