PAFS
Dec 11, 2019Follower
Orbi Tri-band Whole Home Mesh Wi-Fi System with 2.2Gbps Speed (RBK23)
Hi I have just bought this and do not seem to ba able to get it to work unless it is plugged into the existing TalkTalk router? It seems odd to have a TalkTalk router and then the ORBI Router. Can...
Dec 11, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
PAFS wrote:Hi
Can anyone advise please?
Philip
