abkh
Dec 11, 2019Aspirant
RBR50 connection drops for FTTC NBN Connection
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. My connection drops every now and then (aprox every hour). To fix the problem I have to login to my router's and do a DHCP release a...
Dec 11, 2019Guru - Experienced User
Retired_Member
Dec 11, 2019
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
You forgot (edit) something:
- abkhDec 11, 2019Aspirant
Modem is netcomm ndd-0300
My Orbi Router Firmware Version : V2.3.5.30
- FURRYe38Dec 11, 2019Guru - Experienced User
Is this is a modem only or do you know if it has a built in router by chance?
Has the modem been fully powered OFF along with the RBR for 30 seconds then back on?
Any Wifi Neighbors near by? If so, how many?Does a wired PC directly connected to the modem exhibit the same problem or no?
abkh wrote:Modem is netcomm ndd-0300
It is just a plan vanilla modem but supplied by NBNCo (Broadband wholesaler)- Network_Termination_Device_(NBN) - FTTC.
Yes turning off and on the modem temporariy solves the problem. But after an hour it the connection drops again.
But instead of the modem off and on, I just goto my router's admin page and do DHCP release and renew; which also temporarily solves the problem.
