gobananasnet
Oct 10, 2020Apprentice
RBR50 "Connection Hell" since the new firmware update v2.5.2.4
RBR50 "Connection Hell" since the new firmware update v2.5.2.4. A few days ago everything seemed ok, all 30+ devices were connecting. Now since the firmware updated a few days ago 75% of our 30+ devic...
Oct 11, 2020Guru - Experienced User
Be sure you power OFF the RBR and RBS for 1 minute then back ON after a FW udpate. IF you still notice odd problems, try a factory reset and setup from scratch and check again.
gobananasnet
Oct 12, 2020Apprentice
I had already done all of that. That problem remians unchanged. UGH!
- FURRYe38Oct 12, 2020Guru - Experienced User
Revert back to v16 on the RBS first, then RBR lastly. Reset and setup from scratch.
- gobananasnetOct 17, 2020Apprentice
"Connection Hell" remains unchanged. Seriously thinking Netgear has lost its way and should abandon for another manufacturer. This is insane what I'm dealing with. UGH!
- FURRYe38Oct 17, 2020Guru - Experienced User
