gpeck54
Jun 11, 2020Aspirant
RBR50 connection issues.
Orbi needs to be reset 1 to 4 times a day. It seems to start this after a small power outage or I have turned it off for some reason. After a couple of weeks it seems to get better until the next ep...
Jabberwocky123
I have an RBR40 and am running into a similiar issue. For the last week, the router decides to stop working at random intervals. Probably 2-3 times a day. My devices appear to be connected to the network, but they are unable to connect to the internet. When this occurs, I cannot log into the router using either 192.168.1.1 nor can I connect via the mobile app.
This issue affects both wifi and wired connections.
I have not tried doing a factory reset, yet. I will probably try that next. I do have the latest firmware installed.
Please help!
