gpeck54
Jun 11, 2020Aspirant
RBR50 connection issues.
Orbi needs to be reset 1 to 4 times a day. It seems to start this after a small power outage or I have turned it off for some reason. After a couple of weeks it seems to get better until the next ep...
Jun 11, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
gpeck54 wrote:Orbi needs to be reset 1 to 4 times a day. It seems to start this after a small power outage or I have turned it off for some reason.
After a couple of weeks it seems to get better until the next episode.
I have done firmware updates and did a factory reset without any results. Also done numerous power recycles with modem.
It may be a coincidence, but these problems seem to have started when i tried the trial version of Armor Security. The month I trialed that it started to be reset everyday. It has continued after the trial and is no longer being used.
- gpeck54Jun 13, 2020Aspirant
I have the current version of Firmware for the Orbi. My modem is a Arris Surfboard SB8200 recommended by Atlantic Broadband which is my cable provider.
WiFi is just a appliance like the refrigerator anymore. If it was not working well I'm sure I would be lost.
I changed everything on your list I could find under Routerlogin advanced settings. I put channel to 11 instead of auto. I enabled Beamforming and MIMO. I disabled Daisy Chain. I couldn't find how to disable the other items. Also i set the preamble to short.
I have had to reset router 3 times in the last 12 hours. Am at a loss.
- FURRYe38Jun 13, 2020Guru - Experienced User
I would open a support ticket with NG support and ask for additional help and information. Might ask about an RMA as well.
https://www.netgear.com/support/#
Good Luck.
