MOmair
Oct 22, 2022Aspirant
RBR50 Constant Reboot (every 30 seconds)
Hi, I have been using Orbi (RBR50 + 1 x RBS50) since last 3 years. I had no issues whatsoever. Since last week, RBR50 has been restarting every 30 seconds. I have tried updating to the latest firmwa...
Oct 23, 2022Guru - Experienced User
Try swapping one of the power supplies from the satellite with the router.
Maybe the power supply is going bad
- MOmairOct 23, 2022Aspirant
Thankyou for taking the time out to reply. I have tried using 2 other power supplies. One from satellite and one borrowed from another friend. Result is the same.
Is there a way I can find out what's causing the reboot. I am at the brink of going crazy over this failure of a hardware, working my job during the day and trying to unbrick this during the nights.
So far I have tried:
- Using Orbi in AP mode.
- No ISP router connected
- No Satellites connected
- Flashing Voxel firmware but I wasn't able to boot and access orbilogin.net
- Flashed back to latest version
- Hard reset (30 seconds) after fw update
- Soft reset (blinking power light) after fw updates
- Power off, unplug every thing, then turn on after 30 mins
Currently using stock fw v 2.6.1.40. Boots fine, solid magenta light, WIFI dropping again and again.
- CrimpOnOct 23, 2022Guru - Experienced User
Something appears to be inconsistent. If the router reboots every 30 seconds, that does not allow enough time to do much of anything, such as
- Manually install a different firmware version?
- Change from router to AP mode?
To me, there is a difference between the router actually rebooting and the WiFi signal disappearing.
Would like to help, but am confused about the problem statement. Sorry.
- MOmairOct 25, 2022Aspirant
My humble apologies for causing the confusion. I am hardly getting any wifi in my room with my old tplink archer 7 (cement house). I posted 2 updates over the weekend but somehow they didn't get posted as wifi must've disconnected on my laptop.
Update:
On latest firmware, i get constant reboots. I downgraded until I reached 2.6.1.40 and now it has stopped rebooting. I am getting a solid magenta light, lan and wifi dropping every 30 seconds. At least, it is not rebooting constantly. Internet is not working even though its connected by LAN to my router. I am using it in AP mode so I cannot access the webui. On searching this community and snbforums for solid magenta light, it was recommended to factory reset the orbi which I have done multiple times yet the magenta light comes back. Wifi/lan connections keep dropping constantly every 30 seconds.I am at the verge of pulling my hair trying to bring back to life my last purchase ever of netgear products. I have preferred netgear products for over 15 years. There was nothing a good old factory reset or firmware update couldn't solve with those routers. They were solid investments with reliable results. Orbi, however is a huge disappointment. All my surveillance cameras stand disconnected. I have wasted more than 6 full nights trying to fix this issue. Phew! This rant was long over due!
