Linsay000
Feb 16, 2020Aspirant
RBR50 continues to drop wifi
Several times a day, my computer is able to connect with my Orbi, however it is no longer connected to the internet. It isn't my modem because I'm able to use my internet on an ethernet cord from t...
- Feb 22, 2020
If you mark post "Solved", that will help othe users.
Feb 17, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router her by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
