Linsay000
Feb 16, 2020Aspirant
RBR50 continues to drop wifi
Several times a day, my computer is able to connect with my Orbi, however it is no longer connected to the internet. It isn't my modem because I'm able to use my internet on an ethernet cord from t...
- Feb 22, 2020
If you mark post "Solved", that will help othe users.
Feb 20, 2020Guru - Experienced User
Any progress on this?
Linsay000 wrote:Several times a day, my computer is able to connect with my Orbi, however it is no longer connected to the internet. It isn't my modem because I'm able to use my internet on an ethernet cord from the modem
I have made sure my firmware is up to date and have unplugged my Orbi overnight.
It is several years old now, so I am wondering if that is the issue. We have been considering purchasing the outdoor satellite, but don't want to spend the money if my whole system is going bad.
I'd appreciate any suggestion. I typically can follow diretions but am not highly tech literate anymore!
thanks,
Linda
- Linsay000Feb 22, 2020Aspirant
Yes, sorry I didn't reply I haven't been able to get onto my computer time-wise. I called my cable company and had them bridge my modem and it is working great now. It hasn't dropped since then. Thank you for the suggestion!
- CrimpOnFeb 22, 2020Guru - Experienced User
