Linsay000
Feb 16, 2020Aspirant
RBR50 continues to drop wifi
Several times a day, my computer is able to connect with my Orbi, however it is no longer connected to the internet. It isn't my modem because I'm able to use my internet on an ethernet cord from t...
- Feb 22, 2020
If you mark post "Solved", that will help othe users.
Linsay000
Feb 22, 2020Aspirant
Yes, sorry I didn't reply I haven't been able to get onto my computer time-wise. I called my cable company and had them bridge my modem and it is working great now. It hasn't dropped since then. Thank you for the suggestion!
CrimpOn
Feb 22, 2020Guru - Experienced User
