Carnold1978
Jan 11, 2025Aspirant
RBR50 coverage for son's computer gaming
Hello! I purchased the Orbi RBR50 Mesh system 6 years ago (2019). Router and one satellite. Router is Firmware v2.7.4.24 and satellite is v2.6.2.4. I know it's an old unit and I believe firmware ...
CrimpOn
Jan 11, 2025Guru - Experienced User
Good analysis. Those are the options I would suggest. Ethernet cable direct to the Orbi RBR50 router will be the highest performing solution. Depending on what equipment the ISP has installed, bypassing the Orbi router may not work at all.
You are SO fortunate that installing an Ethernet cable is a practical solution. For many people, that is simply impractical.
