tbart1016
Aug 02, 2020Aspirant
RBR50 Coverage Issue
I have the ORBI RBR50 mesh system. My home is 3000 SQF with an upstairs. The router in located in my office at the front corner of my house and the satelite is approximately 30 feet away in the oppos...
Aug 02, 2020Guru - Experienced User
I
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
tbart1016
Im going to try the things you sugested, but I was using firmware 2.3.5.30, however I just upgraded to 2.5.1.16. I see 3 other wifi networks from my neighbors but only 1 consistently. We're all 1 acre plus in this neighborhood. The modem is a Motorola SURFboard SB6141.
- FURRYe38Aug 02, 2020Guru - Experienced User
Try the suggestions first. If nothing changes, update FW then.
tbart1016 wrote:Im going to try the things you sugested, but I was using firmware 2.3.5.30, however I just upgraded to 2.5.1.16. I see 3 other wifi networks from my neighbors but only 1 consistently. We're all 1 acre plus in this neighborhood. The modem is a Motorola SURFboard SB6141.
- MstrbigAug 02, 2020Master
Where is your daughter's room in conjunction with the Main unit?
My setup is similar, large home over 3000 sq. ft., router on one end downstairs, satellite on 2nd floor other side of home, approximately 30 ft distance, maybe more. I have a 3rd satellite in another building, opn the property. The bedroom opposite the satellite on the second floor, connects to the master node, and gets a great signal with no buffering.
Check to see what node your daughter's room's devices are connecting to?
I had 2 cameras that kept connecting to the wrong node. I shut them down and turned them back on and they found the closer node.
- tbart1016Aug 02, 2020Aspirant
All the bedrooms are down stairs as well as the office. Picture a square, the office is in the front right corner and my daughters room is in the back right corner.in between the office and her room is the living room, of course theres a wall betwwn the office and the living room.
How do you see what nodes are being connected to?
Can use the orbi app or log into the RBS web page to see whats connected at the RBS.
tbart1016 wrote:All the bedrooms are down stairs as well as the office. Picture a square, the office is in the front right corner and my daughters room is in the back right corner.in between the office and her room is the living room, of course theres a wall betwwn the office and the living room.
