tbart1016
Aug 02, 2020Aspirant
RBR50 Coverage Issue
I have the ORBI RBR50 mesh system. My home is 3000 SQF with an upstairs. The router in located in my office at the front corner of my house and the satelite is approximately 30 feet away in the oppos...
tbart1016
Im going to try the things you sugested, but I was using firmware 2.3.5.30, however I just upgraded to 2.5.1.16. I see 3 other wifi networks from my neighbors but only 1 consistently. We're all 1 acre plus in this neighborhood. The modem is a Motorola SURFboard SB6141.
Aug 02, 2020Guru - Experienced User
Try the suggestions first. If nothing changes, update FW then.
tbart1016 wrote:Im going to try the things you sugested, but I was using firmware 2.3.5.30, however I just upgraded to 2.5.1.16. I see 3 other wifi networks from my neighbors but only 1 consistently. We're all 1 acre plus in this neighborhood. The modem is a Motorola SURFboard SB6141.
