VueUser
May 14, 2021Initiate
RBR50 crashing since updating to V2.7.2.104
Need Help !!! My wifi has crashed twice since I updated firmware. My modem is fully operational each time and the only way I can get back operational is to unplug BOTH Modem and RBR50 and reboot ...
May 14, 2021Guru - Experienced User
What I'd try (and the order I'd start with)?
1. disable daylight savings time and the traffic monitor and reboot the rbr
2. factory reset the router and do a clean reinstall (not from backup)
3. downgrade the firmware.
