pup0975
Apr 07, 2022Star
RBR50 crashing
My RBR50 has been crashing intermittently for about 6-7 months now. Sometimes it can go weeks without crashing but then will have times where it'll crash a couple of times in 1 week. What I mean by c...
Apr 07, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Is Armor, Circle or Traffic Meter enabled?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Try this version of FW?
pup0975
Apr 07, 2022Star
Thanks for the suggestions:
Have about 3800 sqft. My satellites are on different floors from the main router and are more than 30 ft apart.
I do have traffic meter turned on. Amor and Circle are not turned on.
I'm currently with ATT Fiber using the Arris BGW210-700. I just changed from Spectrum Cable Internet to ATT 3 weeks ago. I had the same issues with Spectrum. I was hoping that maybe something with Spectrum was crashing my Orbi, but now it appears it's just the Orbi.
I've turned off the traffic meter and have changed the settings on the other link. If it crashes again, I'll try the v2.7.3.23. Wonder why they never released this version officially?
