--mark--
May 26, 2022Initiate
RBR50 Dead? :(
Hi all, I'm hoping someone can give me some advice on what appears to be a dead RBR50. I came home from work yesterday to compliants that "there's no internet". I have an Orbi mesh network, and an RB...
May 26, 2022Guru - Experienced User
I've gotten tftp to flash when its flashing white.
You can also try nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
