LokiNV
Apr 03, 2022Tutor
RBR50 dead
Any ideas for an ORBI RBR 50 that is reduced to only a green power light? I don't even get links on ethernet connections. When I do a factory reset procedure on it I get a brief moment in time the factory WiFi setting comes up but the net only lasts 1-2 minutes before going offline. When I do manage to connect to it no DHCP or IP configuration.
have you tried a factory reset? Push and hold reset for up to 30 seconds while powered on.
If that doesn't help, you can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- LokiNVTutorI’ve tried multiple factory resets. Tftp is a no go. Can’t even get an Ethernet link.
LokiNV wrote:
I’ve tried multiple factory resets. Tftp is a no go. Can’t even get an Ethernet link.did you watch the video? Or read it? you're setting a static ip address and forcing it. You won't "show a link".
And saying its a no go doesn't tell us what failed if you did try it. Or even if you tried nmrpflash.
And sometimes with both, it takes a few attempts because they're sensitive to timings.
