Embattle
Nov 01, 2021Guide
RBR50 Deregister
So I intend to pass on my Orbi RBR50 system but of course it is registered to me and naturally doing a reset doesn't remove this, so is there anyway to do this easily or should I contact someone to g...
Nov 01, 2021Guru - Experienced User
NG support would be best.
- EmbattleNov 01, 2021Guide
How would I go about that since it is limited to 90 days, is there some other way to contact them?
- plemansNov 01, 2021Guru - Experienced User
Under the FAQ for registration, there's an email address you can try messaging.
https://kb.netgear.com/1160/NETGEAR-Product-Registration-FAQ
