Kdillon120
Dec 08, 2020Aspirant
RBR50 Device manager not showing any devices after firmware upgrade
Was having speed issues so Netgear tech performed firmware update to V2.7.1.60. Improved the speed but created problems with the Orbi app on my Iphone. The Device manager doesn't recognize any device...
Dec 08, 2020Guru - Experienced User
What version of FW did you have loaded before?
Try downgrading to v40:
Might do a factory reset and setup from scratch after downgrading.
- ricktraDec 08, 2020AspirantI had upgraded to the latest firmware I think it's like 2.7.1 when the problem started. I then went to previous version via manual update using 2.7.0 . Problem seems to be resolved just not sure what I'm sacrificing by downgrading to the previous firmware version.
