Weberdee
Nov 09, 2019Aspirant
RBR50 diconnecting from internet
Hi I have an Orbi RBR50 connected to a satelite RBS50 linked via the RBR50 to a BT modem. Sometimes our internet connection stops and this is now happening more frequently, Its now been 2 days in a...
Nov 09, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Weberdee wrote:Hi
Sometimes our internet connection stops and this is now happening more frequently, Its now been 2 days in a row.
When this happens we cannot access the rest of our network. Hence I believe it to be related to the RBR50.
If I disconnect power to the RBR50, wait and power up again, then the internet connection is re-established.
Any suggestions welcome.
