JBuddenbrooks
May 30, 2020Guide
RBR50 different download speeds for different Macs
I have three Macs in my home. MacBokPro Mid-2012 with OS 10.15.4, an iMac Late 2015 with OS 10.14.6 and a Mac Mini Late 2012 with OS 10.15.4. The first two Macs achieve a D/L speed of 28 Mbs U/L sppe...
Jun 07, 2020Guru - Experienced User
Keep in mind that when testing speeds. Test WIRED first always. Wired is less prone to interferences and odd things seen in wifi. Wifi has alot of different factors and variiables that cause inaccurate or bad results.
JBuddenbrooks
Jun 07, 2020Guide
I do want to check the speed using an Ethernet connection to my Mac Mini. Question is, is it as simple as connecting one of the available Ethernet ports to the Ethernet port on my Mac Mini? A short while back I tried that with my Arris TM 3402A cable modem only to discover that plugging in a Ethernet cable to a second Arris Ethernet port disabled the first port, the one that is connected to my RBR50! I then read the literature who's link you so helpfuly supplied only to discover that you can only use one Ethernet port on the Arris at a time? Why, in heavan's name to they supply four then?
This will be a temporary test only though, since I want to use WiFi for safety's sake.
- Mikey94025Jun 07, 2020Hero
Yes, it's as simple as connecting your Mac Mini to any one of the available LAN ports on your Orbi (base or satellite). The Orbi is a router so it can connect multiple devices. Your cable modem is not a router so it can only support a limited number of IP addresses (i.e., connected devices). That's why you use both a cable modem AND the Orbi router.
Some internet providers supply combination modem/router devices. Your Arris may also be able to support multiple IP addresses at once for customers who upgrade their service to do that. Most home users only have one IP address from their internet provider.
- JBuddenbrooksJun 08, 2020Guide
Mikey94025/FURREY38 et. al.:
A short while ago I connected my RBR50 to my Mac Mini (late 2012) OS 10.15.4 via an Ethernet cable and as I suspected the connection speed increased from 20 Mbs Down (WiFi) to 28 MBs Down (Ethernet). Since to prefer, for safety reasons, to not use a wired (Ethernet) connection to my Mac Mini I'm back to 20 Mbs Down. I may just have to live with this 30% speed penalty but, even if I do, I would very much like to know why this issue occurs. My two other Macs - MacBook Pro (13-inch Mid 2012) 9,2 with OS 5.15.4 and iMac (Retina 5K 27-inch Late 2015) 17,1 with OS 5.14.6 are usually both located at the other end of the house and both register a 28 Mbs Down speed - they are receiving their WiFi from my two RBS50 satellites. Even when I take the MacBook Pro and place it next to my Mac Mini it exhibits a 28 Mbs Down speed. Just doesn't make aense to me! The Mac Mini is located approximately 10-feet from the RBR50. All Orbi's have 2.5.1.16 Firmware.
Any suggestions as to where I can get a answer to this mystery would be super-greatly appreciated.
(P.S. Mikey: Totally off the subject - Is the numeric portion for your name related to your ZIP code? I ask because that's my former ZIP code.)
- FURRYe38Jun 08, 2020Guru - Experienced User
It maybe the wifi adapter in the mac mini that is the cause or problem. If your other Macs are working and the mini isn't the same, it would be the wifi radio in the mini. From my experience, the design of the case could be a factor as well. Minis are not known for great performances on wifi. If you can live with it, then you can do that. Or you could install a wireless USB adapter and use this adapter as your upgraded wifi radio. I have connected a D-Link DWA-192 to my Mini and worked well. Or you can connect a wireless media bridge to the Orbi system and LAN connect the mini to the back of the wireless bridge for an upgraded wifi solution.
- JBuddenbrooksJun 10, 2020Guide
FURRYe38:
Both you and an Mac guy in the OPS Center in my local ISP recommended the D-Link DWA-192. I checked on Amazon and was amazed at the very modest price. I just ordered one. Someone suggested another WiFi Adapter for a great deal more money (~$150) and I seems that I can possibly get what I need for much, much less. My only reservation is that this Adapter is only the 2.4Mhz. but, if this does the job I won't worry about a dual-band unit.
- FURRYe38Jun 10, 2020Guru - Experienced User
Hope you find something that works for your mac mini.
I enjoy the 192 adapter. Though were waiting on drivers for Catalina. The 192 supports WPA3 which is nice. :manwink:
Hopefully, your word "were" has been overcome by events. In anticipation of receiving my Adapter I think I've downloaded the correct Driver. <https://www.tp-link.com/us/support/download/tl-wn725n/#Driver>. Looks as though they published the Driver last December. Am I mistaken?
:smileyfrustrated:Sorry! BIG Ooops. What I purchased was the TP-Link TWN725N. The price of the D-Link scared me away. So, the Driver link I sent was for the TP-Link NOT the D-Link. I am running Catalina so not having a Driver for 10.15 would be a showstopper.
Good Luck. I wouldn't recommend anything TP-Link.
D-Link is working on a Catalina driver for the 192.
- JBuddenbrooksJun 11, 2020Guide
FURRYe38:
Much thanks for all your advice and ecouragement. I know you're not a fan of the TP-LINK TL-WN725N but TP-Link does have software for Catalina and the TP-LINK is very inexpensive and should arrive in a few days. One drawback is that it only works on 2.4 GHz - not dual-band. I haven't ruled out purchasing a more expensive dual-band device such as the D-LINK DWA-192 (when they have Catalina software). But in the interim I thought of one analysis that might be worthwhile. I created a Wireless Diagnostic Report of my current configuration and was wondering if you'd be interested in examining it. As you undoubtedly know the report is a very large file (255 MB!) so I would not try to email it to you. If you would be willing to look at it I can download it to a site where you can upload it whenever you choose to from a URL I'd send you. Maybe the report will point out something to you. I suspect something else is creating my problem since the Wireless Diagnostic Report indicates Excellent Signal quality. See the attached file, from Wireless Diagnostic Info.
- FURRYe38Jun 11, 2020Guru - Experienced User
Just wanted to try my 192 adapter out since i updated one of my Mojave paritions the other night on my Mac Book Pro. So the 192 driver was previously installed on Mojave. Mojave was updated to Catalina. Connected my 192 adapter and turned OFF the onboard wifi radio. Enabled the 192 adapter driver and it's connected as I type this.
Anyways, I recommend that you open a support ticket with Apple support for the one Mac that seems to be havng issues. I presume the mac maybe out of warranty. However I would find out if others in the Mac Community thats seeing any wifif problems. Is there a local Mac or apple shop that does Mac repairs? Would be one good start there. Have someone there look at your wifi diagnotic logs from the one mac.
- FURRYe38Jun 16, 2020Guru - Experienced User
Just FYI, D-Link just released OSX 10.15 drivers for the DWA-192. :smileywink:
