LeeTaylor
Mar 25, 2020Tutor
RBR50 Direct Fibre into WAN issues
I have Hiper direct fibre into the house. The guys from Hiper showed me how to connect directly to the Orbi using vlan tagging setting the port to 101, all other parameters the same. The fibre routre...
Mar 25, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? If there is a built in router here,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would disable Circle while troubleshooting first.
LeeTaylor
Mar 25, 2020Tutor
Here is the log for today........
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 15:13:48
[DHCP IP: 192.168.1.3] to MAC address 20:df:b9:19:bc:5b, Wednesday, March 25, 2020 15:12:27
[admin login] from source 192.168.1.8, Wednesday, March 25, 2020 15:11:26
[DHCP IP: 192.168.1.35] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 15:11:18
[DHCP IP: 192.168.1.32] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 15:11:16
[DHCP IP: 192.168.1.35] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 15:11:15
[DHCP IP: 192.168.1.32] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 15:11:11
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 15:08:12
[DoS Attack: Ascend Kill] from source: 8.8.4.4, port 53, Wednesday, March 25, 2020 15:00:49
[DoS Attack: Ascend Kill] from source: 8.8.8.8, port 53, Wednesday, March 25, 2020 15:00:49
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 14:52:29
[DHCP IP: 192.168.1.16] to MAC address 90:e1:7b:47:49:7c, Wednesday, March 25, 2020 14:50:46
[DHCP IP: 192.168.1.3] to MAC address 20:df:b9:19:bc:5b, Wednesday, March 25, 2020 14:38:33
[DHCP IP: 192.168.1.24] to MAC address bc:fe:d9:7c:88:9c, Wednesday, March 25, 2020 14:19:59
[DHCP IP: 192.168.1.16] to MAC address 90:e1:7b:47:49:7c, Wednesday, March 25, 2020 14:19:48
[admin login] from source 192.168.1.8, Wednesday, March 25, 2020 14:10:58
[DHCP IP: 192.168.1.24] to MAC address bc:fe:d9:7c:88:9c, Wednesday, March 25, 2020 14:09:01
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 14:04:54
[DHCP IP: 192.168.1.19] to MAC address b4:9c:df:86:fb:43, Wednesday, March 25, 2020 14:01:44
[DHCP IP: 192.168.1.24] to MAC address bc:fe:d9:7c:88:9c, Wednesday, March 25, 2020 14:01:35
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 13:59:51
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:56:40
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 13:53:42
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:52:57
[DoS Attack: ACK Scan] from source: 130.211.50.202, port 443, Wednesday, March 25, 2020 13:48:49
[DHCP IP: 192.168.1.34] to MAC address c8:34:8e:36:64:87, Wednesday, March 25, 2020 13:48:48
[DoS Attack: ACK Scan] from source: 130.211.50.202, port 443, Wednesday, March 25, 2020 13:48:28
[DoS Attack: RST Scan] from source: 104.28.12.186, port 443, Wednesday, March 25, 2020 13:48:22
[DoS Attack: ACK Scan] from source: 104.28.12.186, port 443, Wednesday, March 25, 2020 13:48:22
[DoS Attack: RST Scan] from source: 104.28.12.186, port 443, Wednesday, March 25, 2020 13:48:19
[DoS Attack: ACK Scan] from source: 104.28.12.186, port 443, Wednesday, March 25, 2020 13:48:19
[DoS Attack: ACK Scan] from source: 130.211.50.202, port 443, Wednesday, March 25, 2020 13:48:18
[DoS Attack: RST Scan] from source: 104.28.13.186, port 443, Wednesday, March 25, 2020 13:48:16
[DoS Attack: ACK Scan] from source: 104.28.13.186, port 443, Wednesday, March 25, 2020 13:48:16
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 13:48:09
[DoS Attack: ACK Scan] from source: 130.211.50.202, port 443, Wednesday, March 25, 2020 13:48:00
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 13:47:58
[DoS Attack: ACK Scan] from source: 130.211.50.202, port 443, Wednesday, March 25, 2020 13:47:55
[DoS Attack: RST Scan] from source: 216.58.213.238, port 443, Wednesday, March 25, 2020 13:47:51
[DoS Attack: ACK Scan] from source: 216.58.213.238, port 443, Wednesday, March 25, 2020 13:47:51
[DoS Attack: RST Scan] from source: 172.217.218.189, port 443, Wednesday, March 25, 2020 13:47:47
[DoS Attack: ACK Scan] from source: 172.217.218.189, port 443, Wednesday, March 25, 2020 13:47:47
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 13:47:31
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:47:26
[DHCP IP: 192.168.1.19] to MAC address b4:9c:df:86:fb:43, Wednesday, March 25, 2020 13:47:11
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 13:47:03
[DHCP IP: 192.168.1.24] to MAC address bc:fe:d9:7c:88:9c, Wednesday, March 25, 2020 13:46:57
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:46:20
[DHCP IP: 192.168.1.19] to MAC address b4:9c:df:86:fb:43, Wednesday, March 25, 2020 13:46:17
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:46:15
[DHCP IP: 192.168.1.35] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 13:46:08
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 13:46:03
[DHCP IP: 192.168.1.19] to MAC address b4:9c:df:86:fb:43, Wednesday, March 25, 2020 13:45:57
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:45:56
[DHCP IP: 192.168.1.19] to MAC address b4:9c:df:86:fb:43, Wednesday, March 25, 2020 13:45:55
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:45:51
[DHCP IP: 192.168.1.32] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 13:45:38
[DHCP IP: 192.168.1.16] to MAC address 90:e1:7b:47:49:7c, Wednesday, March 25, 2020 13:19:38
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 13:12:18
[DHCP IP: 192.168.1.16] to MAC address 90:e1:7b:47:49:7c, Wednesday, March 25, 2020 13:05:44
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 12:52:59
[DoS Attack: ACK Scan] from source: 143.204.233.96, port 443, Wednesday, March 25, 2020 12:50:47
[DoS Attack: ACK Scan] from source: 185.151.204.9, port 443, Wednesday, March 25, 2020 12:50:45
[DoS Attack: ACK Scan] from source: 143.204.233.96, port 443, Wednesday, March 25, 2020 12:50:43
[DoS Attack: ACK Scan] from source: 185.151.204.9, port 443, Wednesday, March 25, 2020 12:50:41
[DoS Attack: ACK Scan] from source: 143.204.233.96, port 443, Wednesday, March 25, 2020 12:50:39
[DoS Attack: ACK Scan] from source: 185.151.204.9, port 443, Wednesday, March 25, 2020 12:50:33
[DHCP IP: 192.168.1.24] to MAC address bc:fe:d9:7c:88:9c, Wednesday, March 25, 2020 12:46:36
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 12:44:34
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 12:40:59
[DoS Attack: RST Scan] from source: 172.217.19.78, port 443, Wednesday, March 25, 2020 12:40:17
[DoS Attack: ACK Scan] from source: 172.217.19.78, port 443, Wednesday, March 25, 2020 12:40:13
[DoS Attack: ACK Scan] from source: 172.217.218.189, port 443, Wednesday, March 25, 2020 12:39:54
[DHCP IP: 192.168.1.35] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 12:29:31
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 12:15:25
[DHCP IP: 192.168.1.11] to MAC address b4:9c:df:86:9f:40, Wednesday, March 25, 2020 12:14:19
[DHCP IP: 192.168.1.32] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 12:14:03
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 12:11:56
[DHCP IP: 192.168.1.32] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 12:11:35
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 12:11:33
[DHCP IP: 192.168.1.33] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 12:10:54
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 12:09:47
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 11:45:18
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 11:31:18
[DoS Attack: ACK Scan] from source: 17.248.147.208, port 443, Wednesday, March 25, 2020 11:26:48
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 11:24:10
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 11:09:39
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 11:05:38
[DHCP IP: 192.168.1.34] to MAC address c8:34:8e:36:64:87, Wednesday, March 25, 2020 11:05:01
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 11:03:35
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 11:01:30
[DoS Attack: ACK Scan] from source: 54.243.200.195, port 443, Wednesday, March 25, 2020 10:55:54
[DoS Attack: Ascend Kill] from source: 8.8.4.4, port 53, Wednesday, March 25, 2020 10:49:25
[DoS Attack: Ascend Kill] from source: 8.8.8.8, port 53, Wednesday, March 25, 2020 10:49:25
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 10:48:05
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 10:47:28
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 10:46:08
[DoS Attack: RST Scan] from source: 2.17.0.98, port 443, Wednesday, March 25, 2020 10:44:40
[DoS Attack: ACK Scan] from source: 2.17.0.98, port 443, Wednesday, March 25, 2020 10:44:40
[DoS Attack: RST Scan] from source: 143.204.233.39, port 443, Wednesday, March 25, 2020 10:44:13
[DoS Attack: ACK Scan] from source: 143.204.233.39, port 443, Wednesday, March 25, 2020 10:44:13
[DoS Attack: RST Scan] from source: 143.204.233.69, port 443, Wednesday, March 25, 2020 10:44:12
[DoS Attack: ACK Scan] from source: 143.204.233.69, port 443, Wednesday, March 25, 2020 10:44:12
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 10:38:36
[DHCP IP: 192.168.1.2] to MAC address 00:17:88:2e:9a:33, Wednesday, March 25, 2020 10:34:18
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 10:32:58
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 10:24:48
[DHCP IP: 192.168.1.7] to MAC address f0:ef:86:74:7b:3b, Wednesday, March 25, 2020 10:23:53
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 10:10:19
[DoS Attack: TCP/UDP Echo] from source: 8.8.4.4, port 53, Wednesday, March 25, 2020 10:09:03
[DoS Attack: TCP/UDP Echo] from source: 8.8.8.8, port 53, Wednesday, March 25, 2020 10:09:03
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 09:54:42
[DHCP IP: 192.168.1.13] to MAC address f8:6f:c1:62:14:90, Wednesday, March 25, 2020 09:54:05
[WLAN access allowed] from MAC : C8:34:8E:36:64:87, Wednesday, March 25, 2020 09:53:17
[Access Control] Device WIN-00447240 with MAC address C8:34:8E:36:64:87 is allowed to access, Wednesday, March 25, 2020 09:53:17
[DHCP IP: 192.168.1.34] to MAC address c8:34:8e:36:64:87, Wednesday, March 25, 2020 09:53:16
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 09:45:54
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 09:40:04
[DHCP IP: 192.168.1.28] to MAC address e8:36:17:02:b6:ea, Wednesday, March 25, 2020 09:38:14
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 09:34:16
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 09:32:54
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 09:32:29
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 09:30:01
[DHCP IP: 192.168.1.32] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 09:29:43
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 09:29:15
[DHCP IP: 192.168.1.33] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 09:28:34
[DHCP IP: 192.168.1.32] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 09:28:19
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 09:27:06
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 09:26:50
[DHCP IP: 192.168.1.6] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 09:26:12
[DHCP IP: 192.168.1.16] to MAC address 90:e1:7b:47:49:7c, Wednesday, March 25, 2020 09:26:10
[DHCP IP: 192.168.1.6] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 09:26:07
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 09:26:00
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 09:25:59
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 09:25:56
[DHCP IP: 192.168.1.5] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 09:25:51
[DHCP IP: 192.168.1.16] to MAC address 90:e1:7b:47:49:7c, Wednesday, March 25, 2020 09:07:13
[DHCP IP: 192.168.1.22] to MAC address a4:83:e7:55:ca:a0, Wednesday, March 25, 2020 09:01:59
[DoS Attack: TCP/UDP Echo] from source: 8.8.4.4, port 53, Wednesday, March 25, 2020 08:58:17
[DoS Attack: TCP/UDP Echo] from source: 8.8.8.8, port 53, Wednesday, March 25, 2020 08:58:17
[DHCP IP: 192.168.1.27] to MAC address c8:69:cd:a5:7f:1e, Wednesday, March 25, 2020 08:52:05
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 08:51:36
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 08:48:21
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 08:47:12
[DHCP IP: 192.168.1.10] to MAC address a4:83:e7:54:d1:75, Wednesday, March 25, 2020 08:40:19
[DHCP IP: 192.168.1.29] to MAC address dc:a4:ca:b0:aa:6f, Wednesday, March 25, 2020 08:08:29
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 07:51:33
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 07:40:13
[DoS Attack: ACK Scan] from source: 151.101.193.111, port 443, Wednesday, March 25, 2020 07:39:50
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 07:39:00
[DHCP IP: 192.168.1.6] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 07:38:19
[DHCP IP: 192.168.1.5] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 07:38:16
[DHCP IP: 192.168.1.6] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 07:38:16
[DHCP IP: 192.168.1.5] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 07:38:14
[DHCP IP: 192.168.1.23] to MAC address f8:ff:c2:38:4a:2d, Wednesday, March 25, 2020 07:15:11
[DHCP IP: 192.168.1.9] to MAC address 9c:3d:cf:f5:a8:ee, Wednesday, March 25, 2020 07:10:21
[DHCP IP: 192.168.1.28] to MAC address e8:36:17:02:b6:ea, Wednesday, March 25, 2020 07:08:31
[DHCP IP: 192.168.1.8] to MAC address 24:f6:77:05:cd:3c, Wednesday, March 25, 2020 07:08:30
[DHCP IP: 192.168.1.28] to MAC address e8:36:17:02:b6:ea, Wednesday, March 25, 2020 07:08:30
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 07:08:26
[DHCP IP: 192.168.1.17] to MAC address c8:d0:83:ae:c2:b8, Wednesday, March 25, 2020 07:08:25
[DHCP IP: 192.168.1.24] to MAC address bc:fe:d9:7c:88:9c, Wednesday, March 25, 2020 07:08:20
[DHCP IP: 192.168.1.18] to MAC address b0:ca:68:73:14:89, Wednesday, March 25, 2020 07:08:18
[DHCP IP: 192.168.1.5] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 07:05:57
[DHCP IP: 192.168.1.6] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 07:05:53
[DHCP IP: 192.168.1.15] to MAC address 4c:24:98:75:e5:98, Wednesday, March 25, 2020 07:01:40
[DHCP IP: 192.168.1.6] to MAC address 90:9a:77:15:d0:9d, Wednesday, March 25, 2020 07:01:09
[DHCP IP: 192.168.1.5] to MAC address 4c:24:98:0b:a1:1a, Wednesday, March 25, 2020 07:01:04
[DHCP IP: 192.168.1.24] to MAC address bc:fe:d9:7c:88:9c, Wednesday, March 25, 2020 06:44:29
[DHCP IP: 192.168.1.20] to MAC address 80:2b:f9:cb:61:2d, Wednesday, March 25, 2020 06:39:00
[DHCP IP: 192.168.1.16] to MAC address 90:e1:7b:47:49:7c, Wednesday, March 25, 2020 06:34:56
[DHCP IP: 192.168.1.19] to MAC address b4:9c:df:86:fb:43, Wednesday, March 25, 2020 06:32:39
