Larkum
Sep 26, 2019Follower
RBR50 Disconnecting devices at 02:45 am daily
Hay, So this is more of a discussions starter then an issue as I have resolved it now, but wanted to know if anyone knows why it happened and also to maybe help others out. A few days ago I found...
Sep 27, 2019Guru - Experienced User
Have you manually downloaded the Orbi FW files and installed them directly using a wired PC and web browser?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
