MRSAM
Oct 08, 2020Tutor
RBR50 DISCONNECTING ON ALL DEVICES
Hi Everyone, So i read lots of threads regarding this problem and I haven't seem to found the solution. I have the RBR 50 which has been working fine for the 5 months since i bought it, and just ...
MRSAM
Oct 08, 2020Tutor
Hey!
The firmware is V2.5.2.4. I have powered it off and on again but the result is the same as if i just let it reconnect by itself. I have not done a factory reset since the last update. We have 2 wifi neighbors but they aren't that close. I have an RBS connected also.
Oct 08, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- MRSAMOct 08, 2020Tutor
It's a Videotron Helix modem
- FURRYe38Oct 08, 2020Guru - Experienced User
Is this your modem? https://videotron.com/en/support/helix/equipments/helix-fi-gateway
If it is, what mode is is configured for? Router or Bridged?
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode- MRSAMOct 08, 2020Tutor
You're absolutly right. My NAT was double. I reconfigured it so that my router is the only access point. NAT is now open which is great. It's funny I just did this before you replied. Thanks, lets see if the disconnects stop!
And yes the distance is about 40 feet between them and the connection is strong.
