SymonB
Sep 12, 2019Tutor
RBR50 DNS Issues
Have the Orbi RBR50 all on the latest firmware. Have reset the entire router and satellite units. DNS keeps locking up. All devices connect to the Orbi fine yet when accessing the internet it locks u...
Sep 12, 2019Guru - Experienced User
If you're using the default dns provider, that is coming from your ISP not netgear. If the dns isn't working properly and you have it set to automatically get dns, its an issue the ISP is causing. You can change your dns provider to a different provider (google, cloudfare, etc.)
googles is 8.8.8.8 or 8.8.4.4
cloudfare is 1.1.1.1
I would try doing something like this to see if it helps.
