SymonB
Sep 12, 2019Tutor
RBR50 DNS Issues
Have the Orbi RBR50 all on the latest firmware. Have reset the entire router and satellite units. DNS keeps locking up. All devices connect to the Orbi fine yet when accessing the internet it locks u...
SymonB
Sep 12, 2019Tutor
Hi, THanks for the reply. I should have mentioned in my initial message, I tried turning off automatic DNS and had used Googles DNS servers 8.8.8.8 Still the same problem.
Sep 12, 2019Guru - Experienced User
so lets break down the problem. You say the dns is locking up. Describe this more.
What exactly is happening? More details are better than less.
How do you know its a dns issue?
What modem are you using?
you put you're using the latest firmware. This changes frequently. Please list what version you're on for people looking at this in the future.
- SymonBSep 12, 2019Tutor
Hi,
The Firmware version is V2.3.5.30.
Pretty much all devices connect to the router/satellites fine hence no wifi dead spots around the house. The problem is once connected wifi or wired, trying to go out onto the internet is virtually impossible because nothing gets resolved via DNS. It takes forever ranging from 3mins - never before the DNS resolves the query.
Example just connected a laptop to the wifi. Says its connected to wifi full strength but then says no internet connection. Open a web browser and keep getting DNS error messages.
This problem also is playing havoc with my Netgear Arlo cameras whereby its draining the batteries as the cameras costantly try to connect to the internet but can't or eventually after quite some time.
The modem is supplied by the ISP as I have Fibre into the house. its a ZTE model no. ZXHN F620 unit.
- plemansSep 12, 2019Guru - Experienced User
That ZXHN F620 has some integrated routing capabilities within it. You could be running into a double nat situation.
https://kb.netgear.com/30186/What-is-Double-NAT
the zte also has dns provider info within it as well.
You're options are to either setup the ZTE device in passthrough only mode or switch the orbi to AP mode. You could contact your provider and check with them on properly setting the ZTE device to work with your router or try the orbi in ap mode.
Hi,
Thanks for the suggestion.
Having sent you the details of the modem, I looked up the unit and realised it can act as a router too. Weird as the ISP fitted the house with this unit and then shipped out a TP-Link router which was aweful hence I brought the Orbi unit. One would hope they have enabled the modem only and not the full router.
I'll contact the ISP and report back once I have heard from them.
- FURRYe38Sep 12, 2019Guru - Experienced User
If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
