SymonB
Sep 12, 2019Tutor
RBR50 DNS Issues
Have the Orbi RBR50 all on the latest firmware. Have reset the entire router and satellite units. DNS keeps locking up. All devices connect to the Orbi fine yet when accessing the internet it locks u...
MarkMorton72
Mar 31, 2020Guide
Just to echo whats been said before in this thread. Had this happen for the first time last night and a reboot of the RBR solved the problem.
Running RBR50 and three RBS50 satellites with no problems for over a year - been very impressed with the ORBI. Not an IT professional but been around this stuff long enough to troubleshoot most stuff.
So, set up is:
- Virgin Media ISP - router in modem mode
- RBR50
- 3x RBS50 all wifi backhaul
- All on V2.5.1.8
- 35-40 devices on the network, mix of wired/wireless
- Disney Circle enabled (paid for version)
- Armour not enabled
- All DHCP; Auto DNS
What I found echos much of what;s above:
- DNS lookup fell apart suddenly
- Some DNS resolution happening (e.g. could resolve news.bbc.co.uk but not https://www.disneyplus.com) - cache working?
- Couldn't change DNS resolver in the ORBI (due to Circle?)
- Manually changed DNS to 4.4.4.4/8.8.8.8 in iPad settings - so bypass router resolver (192.168.1.1) and worked fine (or appeared to)
- Restarting the RBR50 only fixed it and no problems in the last 14 hours
Looks like an issue with the ORBI running out of some internal resource - maybe circle but I think people without circle enabled are having the probelm?
Would be good for someone at netgear to look at this - it's a showstopper when it happens and we're all working from home right now.
Mar 31, 2020Guru - Experienced User
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thank you.
MarkMorton72 wrote:Just to echo whats been said before in this thread. Had this happen for the first time last night and a reboot of the RBR solved the problem.
So, set up is:
- RBR50
- All on V2.5.1.8
- MarkMorton72Mar 31, 2020Guide
