swansora
Mar 17, 2021Follower
RBR50 DNS Not responding in the last 2 days
The Orbi DNS Server has stoped responding periodicaly. A reboot solves the issue for a couple of hours but then the issue reappears. If I set the DNS servers manually on my machines to my ISP or th...
Blanca_O
Mar 24, 2021NETGEAR Employee Retired
Hi swansora
Engineering has determined that the issue is caused by the Traffic Meter. The quick workaround is to disable the traffic meter.
To disable traffic meter:
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck Traffic Meter
Engineers are working on a firmware fix to be released.
Blanca
Community Team
MrBurntPancake
Jul 26, 2022Aspirant
Its' 2022, I'm on V2.7.3.22, and have exactly the same behaviour. ORBI RBR50 DNS Server temporarily stops working, and all my devices start reporting they're "Connected without Internet". When I manually configure DNS to be 8.8.8.8/8.8.4.4 on my machines, everything starts working perfectly.
I had Traffic Meter enabled, and of course I'm disabling it right away, but how long do your Engineers going to keep working on this? It's been over a year since this was posted! đ
- CrimpOnJul 26, 2022Guru - Experienced User
It is not always a good idea to 'continue' a discussion that is over a year old. The discussion in March, 2021 was about a programming error in the Traffic Meter feature that was triggered by Daylight Saving Time. By April, 2021, the condition disappeared and it was corrected in a firmware release in summer of 2021. It did not reoccur when Daylight Saving Time went into effect this year (2022), so the engineers did in fact "fix it".
Whatever is happening to your RBR50 system now has some other cause.
Have you tried setting the router to use Google DNS? (on the web administration, Internet menu)?
