Aggie88
Mar 22, 2022Apprentice
RBR50 downgraded itself
About an hour ago I lost internet through the house (WiFi and ethernet) and went to investigate. I found the Orbi Router (RBR50) blinking like it does when it is rebooted. It was strange to me sinc...
Mar 22, 2022Guru - Experienced User
You might want to update the RBR back to v.22.
Let us know what happens...
- Aggie88Mar 22, 2022Apprentice
I agree about updating but I wanted to see if it did it on its own overnight. At just after 3AM this morning, the RBR50 updated itself back to .22 per the logs. I'm just perplexed why the downgrade happened but I know that sometime things happen 🙂
- FURRYe38Mar 22, 2022Guru - Experienced User
Is very odd. Have not seen this before. Possible someone at the NG auto update services did something incorrectly and then changed it back.
