spidermanroach
Jan 24, 2021Tutor
RBR50 dropping connection from main Orbi
I have been having trouble with my Orbi RBR50 the past few months with it not connection and flashing the purple ring. I press the sync button on the back of it and sometimes it takes a few times of...
Jan 24, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
I would manually update to v40 and see if this changes anything.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Others have posted having problems with v4 FW.
spidermanroach
Jan 24, 2021Tutor
Motorola OCSIS 3.0 Cable Modum plus AC1600 Router. I have Xfinity.
Model: MG7540
House is about 3200 sq feet. I would say a little over 40 feet or so. 1 in the basement and 1 in my family room.
Yes I am in a regulat neighborhood and there are people with wifi all over. I just do not know enough about how to change the channels and all of that. (Rookie)
Thank you for the info!
- FURRYe38Jan 24, 2021Guru - Experienced User
Also our modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- spidermanroachJan 24, 2021Tutor
I will give that all a try. Thank you for your help.
:smileywink:
