spidermanroach
Jan 24, 2021Tutor
RBR50 dropping connection from main Orbi
I have been having trouble with my Orbi RBR50 the past few months with it not connection and flashing the purple ring. I press the sync button on the back of it and sometimes it takes a few times of...
spidermanroach
Jan 24, 2021Tutor
Motorola OCSIS 3.0 Cable Modum plus AC1600 Router. I have Xfinity.
Model: MG7540
House is about 3200 sq feet. I would say a little over 40 feet or so. 1 in the basement and 1 in my family room.
Yes I am in a regulat neighborhood and there are people with wifi all over. I just do not know enough about how to change the channels and all of that. (Rookie)
Thank you for the info!
Jan 24, 2021Guru - Experienced User
Also our modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- spidermanroachJan 24, 2021Tutor
I will give that all a try. Thank you for your help.
- FURRYe38Jan 24, 2021Guru - Experienced User
:smileywink:
