JMPBE
Jul 26, 2020Follower
RBR50 dropping internet connection intermittently
I have an RBR50 Hub connected to my HFC based ISP router with two satellites (one of them an RBS50 and the other a RBS20) - both satellites have a wired connection as I have a ethernet network throug...
Jul 27, 2020Guru - Experienced User
IF your ISP modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
