gmist26
May 24, 2023Tutor
RBR50 Dropping internet connection
Hello--have had the RBR50 with 2 satellites for roughly 2.5 years and love it. Spectrum recently sent out a new modem (one i did not ask for) because they said my current one was out of date. since...
May 24, 2023Guru - Experienced User
I'm really surprised they sent you the tm1602a.
Its a fairly old modem and is only docsis 3.0 with a 16x4 modem inside.
Not really an upgrade (unless the old one was ancient).
With the push for docsis 3.1, I'd expect something a little newer.
And spectrum makes it hard to log into the modem and check the signal as they lock it down so people can't.
I'd keep pushing on them a bit since the only thing that changed was the modem to cause the issue. they'll always start with "its not our equipment"
