Zbobthecat
Jan 12, 2025Aspirant
RBR50 dropping internet connection
Hello I have an RBR50 with 2 satellites since 2019. I have the same ISP for the same duration. My RBR50 is connected behind the ISP modem. Firmware version is V2.7.5.4 Everything was working fine f...
CrimpOn
Jan 12, 2025Guru - Experienced User
Which part of the router is blinking red? (See page 9 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf )
As long as the router has not rebooted, the Orbi log may give a hint to what has happened. The log is found on the Advanced Tab, Administration Menu:
Ordinarily, it might be appropriate to do a Factory Reset, manually reload the firmware from the support web site:
https://kb.netgear.com/000065539/RBR50-RBS50-Firmware-Version-2-7-5-4
Then do another Factory Reset and configure the router from scratch.
This is complicated because two RBR50 routers have shown the same behavior.
CrimpOn
I neglected to ask
- How many devices are connected to this router?
- Have you ever cleared the 2nd and 3rd tables on the Access Control page?
(devices which are not connected)
My impression is that there is a known programming error in the RBR50 firmware which can cause problems when the configuration file gets "too big". This bug was never addressed when the RBR50 was an active product, and now that this system is "End of Service", Netgear will not spend any money fixing it. (I had the same sort of issue with my 2013 Honda. Not issuing any more Map Updates (that cost $150!). Sort of a f**k you for keeping your Accord for more than 10 years!)
- ZbobthecatJan 13, 2025Aspirant
Hi,
Thanks a lot for your message; when the problem happens, it's the top of the router which is red (= no WAN connection).
I have to try the factory reset; however I have a second RBR50 router (of the same type (RBR50 v2) which I got when I bought a second-hand RBK50 kit (to have an additional satellite) and a few weeks ago I did a factory reset on this spare router and I installed the latest firmware but with this second router I had exactly the same problem ...
I will also try to clear the access control tabs (I have an impressive list for the non connected devices), but again on the spare router this list is almost empty (and I had the same problem as well).
Could it be that my ISP is sending some signals to the modem which arrives at RBR level and which makes it lose the WAN connection ? Strangely this problem is coming up during weekends (so are maintenance operations going on at that moment ?) and after a restart of the router the connection is ok but a few minutes after it drops again.
The problem is that this issue happens for almost an entire day and I do not know how to reproduce it .... For example, the problem showed up on last Saturday : at around 10:00 AM internet connection dropped then I tried to reboot RBR router and my modem a countless number of times but the problem was still there (connection was ok for a few minutes after the restart but then it was down again); it's only on Sunday morning after a n-th reboot of everything that the problem has gone and the connection is stable since then. It was like that several times by the past : connection issues for almost an entire day and then the connection was stable again for several weeks .... Really strange ....
- CrimpOnJan 13, 2025Guru - Experienced User
Does the Orbi log contain any entries at the time this happens?
I didn't check the logs at that moment and the router has been rebooted since then .... I must wait for the next occurence of the problem ...
