DML1-1
Jun 18, 2020Aspirant
RBR50 Dropping Internet Connections with Firmware 2.5.1.16
Since I upgraded my firmware to my RBR50 to version 2.5.1.16, I am losing my Internet connection each day, once or twice, completely, and will drop intermittantly once or twice an hour all the time. ...
Jun 18, 2020Guru - Experienced User
I
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Press the back reset button for 15 seconds then release.
DML1-1
Jun 30, 2020Aspirant
You have given me the playbook on how to fix dropped connections and I appreciate it. However, my question is this, why would upgrading to firmware 2.5.1.16 be the start of these problems? Why wouldn't I have been dropping my Internet connection be a problem with the earlier firmware versions. I didn't make any configuration changes, only upgraded.
- Greg00001Jun 30, 2020Star
DML1-1 wrote:You have given me the playbook on how to fix dropped connections and I appreciate it. However, my question is this, why would upgrading to firmware 2.5.1.16 be the start of these problems? Why wouldn't I have been dropping my Internet connection be a problem with the earlier firmware versions. I didn't make any configuration changes, only upgraded.
I had the same issues as you. Even a factory reset wasn't helpful. The last stable version for me is 2.3.5.30 and I wouldn't go any higher than that unless you like frustration.
- FURRYe38Jun 30, 2020Guru - Experienced User
Sometimes new FW needs a reset as it bring in new items which maybe incompatible with older configurations. So a reset maybe needed as last resort if you encounter problems after a reset. it's a mixed bag on updates, some people don't see problems after a FW update, some do. Try a reset and setup from scratch. IF the problem continues, then you can revert back to what had worked for you. I for one have a well working RBK50 system on v16, however I always reset mine after a FW reset so I avoid most issues.
Also ISP service can also impact operation as well. May work for a time then doing something like a FW update may bring the problem to light which should be addressed. Reason why asking about your ISP services.
It's up to you if you want to give feedback to questions or not. Feedback helps us help you though.
Good Luck.
