cbwilliamsme
Oct 01, 2021Aspirant
RBR50 dropping internet
I have the latest firmware (v2.7.3.22) and am experiencing multiple disconnect events throughout the day (verified by my internet provider) that result in disconnections and very slow reconnections t...
Oct 01, 2021Guru - Experienced User
Is this happening over wired and wireless devices?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- cbwilliamsmeOct 01, 2021Aspirant
Hitron Modem model EN2251
Internet provider: Spectrum - The report seeing intermittent disconnects from the RBR50 as they see it trying to reconnect.
Happening over wired devices: MacBook Pro (satellite) and AppleTV Gen4 (base)
2200 sq ft. home (2 floors plus basement - no devices in basement)
Satellite is about 30ft from base.
WiFi isn't an issue as disconnects are affecting mainly wired devices.
I've pretty much tried everything you've asked and no resolution. Been told by others its a firmware issue and the new firmware version in beta testing fixes the issue. Is there a new version for the RBR50/RBS?
- FURRYe38Oct 01, 2021Guru - Experienced User
You can try this and see:
https://community.netgear.com/t5/Orbi/Missing-Connected-Devices/m-p/2142349/highlight/true#M126110
I recommend a factory reset and setup from scratch after it's installed.
Power OFF the ISP modem for 1 minute as well when you reset the RBR.
- cbwilliamsmeOct 06, 2021Aspirant
I installed the new firmware and did the reset and I'm still dropping connections all over the place. Spectrum won't help because the Orbi model is not an approved router.
Any other thoughts?
Chuck
