milklksubstance
Oct 30, 2019Aspirant
RBR50 dropping packets
I have a RBR50 updated to latest firmware (2.5.0.38). Prior to installing this firmware version, everything was working fine. After installing this firmware, my Orbi is now randomly not responding to...
Retired_Member
Oct 31, 2019
milklksubstance wrote:I have a RBR50 updated to latest firmware (2.5.0.38). Prior to installing this firmware version, everything was working fine.
This should tell you something.
- milklksubstanceOct 31, 2019Aspirant
Upon further review, the problem only happens on wireless. Wired devices work fine, Speedtest from Orbi works fine.
When the wireless is "working", packets are still being dropped. Problem occurs regardless of channel, on both the 5 GHz and 2.4 GHz bands.
I would love to go back to .30. How do I do that?
- Retired_MemberOct 31, 2019
milklksubstance wrote:Upon further review, the problem only happens on wireless. Wired devices work fine, Speedtest from Orbi works fine.
Go to the download page, enter your gear and see if there is an eariler version available.
- milklksubstanceNov 04, 2019Aspirant
This was probably overkill, but I went back to 2.2.1.212, did a factory reset on that firmware, upgraded to 2.3.0.32, changed all my settings to where I wanted them one by one while checking wireless speed at every step (it dropped each time!), then upgraded directly to 2.5.0.38. I do not experience the long connection drops I used to, but the wireless does still drop for about a couple seconds from time to time.
